  3. Orcad Capture cs lite display problem
  • Views 14502
Tester3000
Tester3000 over 13 years ago
Dears,
Whenever I press the Edit simulation profile settings, the tabbed window opens but with missing value fields! I changed the resolution all the way and still not showing the fields its like it needs a resize of the window, and I cant resize it. This only happens on my sony vaio.
However on other laptops and workstation it works fine :<
Any ideas?
btw Am running windows 7
Problem on sony vaio:
 Problem
Normal working condition on other laptops/workstations:
Normal
  • oldmouldy
    oldmouldy over 13 years ago
    You got the Windows 7 font fault, you need the Windows 7 font fix...
    Win7FontFix.zip
  • Tester3000
     Thank you very much! It works!!
  • 1borislav
    1borislav over 11 years ago
    Hi I am having the same probles as Tester3000 but working with windowsXP. Can you give me some advice what should I do?
