  3. Cannot add pins to a block....
  • Subscribers 163
  • Views 15124
springdene
springdene over 13 years ago
I am encountering a problem adding pins to a block. Oddly this is only affecting the right hand side of the block (the output side).
I can add pins (Add Pin>type the pin name> click on the block at the particular location) on the left hand side but the pins refuse to be placed on the right. Oddly on the right hand side of the block there is a pin with no name attribute shown, which i have attemped unsuccessfully to delete. How this came to be here, i do not know (i am a newbie), but i suspect this may be preventing the placement of pins.
How do i remove the unidentified pins?
How do i interrogate the block to identify why i can't attach pins?
 Any help would be appreciated
J
  • Jerry GenPart
    Jerry GenPart over 13 years ago
    Worse case – you can open the block symbol in DEHDL using the File > Open menu option. Navigate to the library location and select the sym_1 symbol view. Then, you can edit the block as needed.
    Jerry
  • springdene
    Jerry,
    Brilliant, I edited it as you indicated, deleted the ‘rogue’ pin and the problem went away..
    Just a little confused as to how the pin ended up there in the first place!
    Thank you
    J
