  3. Error on NC drill (by layer) output file
  • Subscribers 163
  • Views 14561
Jesus Vasquez
Jesus Vasquez over 13 years ago
I am designing a 4 layer board with some blind/buried vias. So on “Manufacture -> NC -> NC Drill” I selected under “Drilling” the option “By layer”. There are then generated 3 output files “file-1-2-np.drl”, “file-2-3-np.drl”and “file-3-4-np.drl”.
In order to probe if everything was all right, I placed on the board 4 mounting holes (the same symbol four times), but on the output files 1-2 and 2-3 I got
X17000Y-17000
X-17000Y-17000
X-17000Y17000
While on the file 3-4 I got
X17000Y-17000
X-17000Y-17000
X-17000Y17000
X17000Y17000
So, one of the hole is only visible on the last layer; something like a blind via but it is actually a passing though hole. I repeated the process several times and the output was always the same. In fact, I discovered that the last hole that I place on the PCB is the one that has the error on the output files. If I choose the option of “Drilling” “Layer pair”, the output file is correct.
Am I missing some configuration? Or maybe am I doing something wrong? Any ideas?
I’m using Allegro PCB designer 16.5
Thank you very much.
