  3. How can i change the Top Component to Bottom Side In (Allegro...
  • Subscribers 162
  • Views 24638
How can i change the Top Component to Bottom Side In (Allegro PCB Editor)?
Dhamodharann
Dhamodharann over 13 years ago
Hi..
     I was using the Allegro PCB Editor(OrCAD 16.0). In that all components are in same side.So only i had asked that doubt to change the component top to bottom.
   This Option is been not enabled in my Edit -> Move and then click the RMB and mirror the component.
  What is RMB ?
Send the details clearly.
  • redwire
    redwire over 13 years ago
     Hi
    RMB = Right Mouse Button
    There are several ways to change sides (mirror) in Allegro.
    1) Edit->Mirror, then click on the part
    2) Edit->Move, click on the part, then RMB, mirror
    3) Place->Manually, click on the part, RMB mirror
    Hope that helps!
  • redwire
     Hi
    Hope that helps!
