  3. Changing grid size
  • Views 21569
Changing grid size
TMCCANN
TMCCANN over 12 years ago
I am trying to place two differential signal lines close together, 8 mils between them. But due to the spacings between the grid points I cant measure the distance between the two traces accurately enough. Is there a way to make the grid size smaller?
  • Mstrghettorigg
    Mstrghettorigg over 12 years ago
    You can change the grid by setup/Grid.
    But I think it would be ideal to set the physical constraints so that the pairs will be routed with 8 mil gap all the way.  (Corners tend to not be perfect on grid)
    Hope this helps.
  • oldmouldy
    oldmouldy over 12 years ago
    PCB Editor? The Slide function will normally be set to "gridless" then the traces will end up at the DRC spacing, regardless of the grid. You can change the grid from Setup>Grids, the Etch Grid controls the routing grid, The Constraint Manager Spacing rules will control the spacing between objects. Display>Measure, window select two objects will get you the Air Gap which is the spacing that PCB Editor cares about as far as the rules are concerned.
  • TMCCANN
    I'll look at the physical constraints and see if it works.
