  3. Changing via types
  • Views 22210
Changing via types
TH Designs
TH Designs over 13 years ago
Lets say I have a net on in a design that is already routed using the default via assigned. Is there a way to change that via on the fly without having to delete it or re-route the trace?
I tried using the "change" command, but it does not seem to have a via specific selection.
Tom
  • rong96
    rong96 over 13 years ago
     Select Tools>Padstack>Replace
  • TH Designs
    Won't that be a "global" change and impact all vias?
    I only want to change specific vias on a specific net.
  • RScott5939
    RScott5939 over 13 years ago
    When you edit padstacks, the dropdown will give you an option to select single vias. If you don't select single, that will change all vias.
    HTH
    Ron Scott
  • rong96
     On theOptions tab you can select "Single via replace mode"
  • TH Designs
    I'll give it a shot, thanks guys!
