  3. Changing PCB Decal Pin Numbers
  • Views 18216
DonlAZ
DonlAZ over 13 years ago
I searched and kept coming up with Zero results.
I have an existing decal and want to change the pin numbering without having to delete and add the pins again with a differnt number for the pins ie vreg versus mossfet. Is there a simple way to do this?
  • DonlAZ
    I was thinking prior I would select the pin and edit its number but now the trying to change the text doesn't work for me either but yes I was in the .dra file
    I selected Edit - Text and that solved it. Thanks for helping me work this through.
