  3. Changing PCB Decal Pin Numbers
  • Views 18213
DonlAZ
DonlAZ over 13 years ago
I searched and kept coming up with Zero results.
I have an existing decal and want to change the pin numbering without having to delete and add the pins again with a differnt number for the pins ie vreg versus mossfet. Is there a simple way to do this?
  • steve
    steve over 13 years ago
    Edit - Change then select the Pin Number you want to change and change it.
  • DonlAZ
    Thanks, I tried that and as soon as I select Change the option to select a pin goes away in the find window. I'm able to select a pin UNTIL I select change. I must be doing something wrong?
  • TH Designs
    TH Designs over 13 years ago
    Do what Steve suggests but also go to the find tab and select "all off" then select "text". This will ensure you only select the text of the pin.
  • steve
    Sorry should have been more specific. To edit the Pin number you MUST be in the symbol editor and be editing the filename.dra file. Edit the pin names here then save and then update the symbol in the design. Remember this is tied to the netlist from the schematic so pin numbers must match.
  • TH Designs
    Try this:
    Edit-Text
    Make sure you have Package Geometry - Pin Number selected for the active Class / Sub Class
    Then click on the pin text and type in the new number.
     This will work assuming you are editing the footprint .dra file as Steve points out.
