  3. Changing width while manual routing
  • Views 14789
TH Designs
TH Designs over 13 years ago
When I go to change trace width while routing, I go to the drop down box under options for "Line Width" and there are 14 entries with 21474836.00. This number also appears in the "Miter" drop down box.
What does this number represent and how do I get rid of it?
Tom
Using PCB Editor, Standard, Latest ISR
  • TH Designs
    steve said:
    The number has either been added by you (or if you changed the units it might be a rounding from mils to mm or similar). This list is stored by PCB Editor for any manual override line widths that you have added. To clear the list, LMB in the line width box and use the backspace key until it is gone then press the TAB key and you will get a confirmation to delete the width.
    It might be better to use Constraint Manager to define and drive the line widths of the nets. Then when you route this value is set already.
    Hi Steve,
    Those values were there the first time I went to the drop down box.
    I do use CM to set specific widths, but there are times when I need to have one net take on different widths depending on where it is in the circuit. I do a lot of designs that utilize higher current where I might have a main power bus of one width and branch off of that to individual circuits with a different width. Same net, different widths.
     Tom
  • TH Designs
    Hi Steve,
     Tom
