  3. Loading skill files
  • Replies 7
  • Subscribers 166
  • Views 16127
Loading skill files
jemarods
jemarods over 12 years ago
hi....
Is there a way to load skill files without using skill loader?
Thanks!
  • oldmouldy
    oldmouldy over 12 years ago
    No, the OrCAD tools don't have the "load" interactive command implemented, you need to use the batch load - works for any license level. Also, restricted debug and development without the "load" interactive command. Use the allegro.ilinit to batch load the skill files.
    allegro_ilinit.zip
  • jemarods
    thanks sir
    i'd try this one
     regards!
  • seyerfred
    seyerfred over 12 years ago
     Hi sir
     how can i generate a skill window on dock control of allegro to view the list of the skill that can i load?
    Thank you..
  • steve
    steve over 12 years ago
    Tools - Utilities - Keyboard commands lists all avaliable commands ( either default or loaded via allegro.ilinit).
  • seyerfred
    keyboard commands lists are defualt in allegro, how about the other skill file?
    is there any syntax to create a window in docking control to view the list in the red rectangle below..
