  3. Autorouting
  • Replies 16
  • Subscribers 168
  • Views 21865
Autorouting
TH Designs
TH Designs over 12 years ago
I normally don't autoroute anything, but I'd like to try it on a board I'm working on. Problem is this board is 8 layers and my seat is limited to 6 layers. I'm thinking I can remove the layers where I have the power and gnd planes from the stack up and disable those nets in CM. Then add the layers back in after the routing has been done.
If this will work, how do I "lock" any existing traces I have routed to prevent the autorouter from moving them?
Tom
  • Mstrghettorigg
    Mstrghettorigg over 12 years ago
    I don't use autorouter either, but I think placing the "fixed" property on the clines will lock these lines.
    I feel like I could never get autorouter to do anything I wanted it to do.  :)  Good luck.
  • TH Designs
    My sentiments exactly.
    There is one area on this board that I want to see if it can save me some time. I have most of the critical stuff in so I figured I'd give it a shot at the rest of the signals. We'll see..........
     Tom
  • redwire
    redwire over 12 years ago
     You have your planes marked as PLANES in the stackup?  Specctra doesn't count power planes against the 6 layer count.
  • TH Designs
    No I don't have them set to planes as they will probably have some nested areas in them. But for the purposes of autorouting I could make them planes and change them later.
  • ScottCad
    ScottCad over 12 years ago
    Tom  the specctra Autorouter is pretty darn good as autorouters go, but the real power with specctra is in its ability to manualy route a board. The interface is a whole lot different than Allegro as it is an old hold out from  the Days of CCT. Things like the silkscreen do not appear in specctra only etch/pins and vias, copper objects, keepouts etc.
    I can tell you without reserve that if you have access to Specctra with your current license and you take the time to give it a whirl you will find you can blow through routing boards. The route editor as it is called in specctra is amazing easy and natural to use. There is also really good intergration with Allegro in that you can launch it from  Allegro etc. The big advantage is that allegro can pass the design rules to specctra so you wont have to bit fiddle setting things up.
    Be aware ! that specctra uses files with the ".dsn" extension "Same as capture" Love that : )
    When you start specctra, It can be started in a few ways. One of them  invokes full autorouting but by default from  Allegro it should just invoke the program  and sit there until you hit the go button in specctra.
    In specctra you use the function "Protect Wires" to disable them  from  getting auto-routed.
    To do this and there are a couple of ways, go to the tool bar and choose "Select > Wires "Sel Wire Mode" or select all to select all wires. Next go to Edit Menu and choose " UN Protect " wires by net. "'Protect and UN Protect" are compined into the same menu ! , You can also protect Vias.
    By way of another tip. Click on the "Edit Route Icon"  Then RMB "Setup"  Good defaults are
    Snap to Pin Orign, Push Routing "Turn off to just hug routes", Allow Redundant wiring on enabled nets and Multiple Pins Connections"
    One More thing. When you launch Specctra at the bottom  Right corner of the screen is a button that is used to show the current units you are using. Make sure this is set correctly. MM for mili meters, mil, inch etc for imperial units. Check this as your first step.
    Others might dis-agree here but for routing a board manually Specctra cant be beat..
    Enjoy : )
    Thanks Scott
