  3. problem in Annotation ??
  • Subscribers 163
  • Views 17053
kabalee
kabalee over 13 years ago
Hi everyone,
in my design i cut  the schematic symbol from one page to another page the part reference is changing what is problem ??
from my schematic design i come to know in annotation mode is changed occurance but default is instance
if i change the mode from occurance to instance that part reference will change right ?
what will i do ???
some time if i give print for schematic the part reference is change what is the problem??
i could not  cut any part (like resistor or capacitor or some other this ) from one schematic page to other page
please help for this post ?
  • oldmouldy
    oldmouldy over 13 years ago
    Your design is in Occurrences mode. Occurrences properties are not copied since there can be many sets of them. When you print, set the print mode to Occurrences - this has been corrected in later versions of 16.5 and 16.6 to be automatically set correctly. You can manually assign the reference when copying if you need to keep the same reference.
  • kabalee
     Thanks oldmouldy,
    but i need to do it instance mode only because i need to move or cut some part from one schematic page to another for aligning perpose.if i  cut that parts and paste it that exiting reference part is changed to new reference  .please help for me
    in my design has nearly 1000 components are available and 65 pages is available ,i need to align all pages ,so i could  not change one by one manually ,it will take too much time how can i correct it ...
  • kabalee
     HI
    how to change occurance mode to instance mode without error or warning (part reference should not change ) Schematic design
    {i am in occurance mode if i cut the part and paste the part ref is changing }
    if i change mode  what will happen in my schematic design
     please reply
