  3. How to generate .asc and .min file?
  • Subscribers 163
  • Views 17750
RobZan
RobZan over 13 years ago
Hi!!
I would like to export file .asc and .min from a board in OrcadPCBEditor 16.6. I remind that with the Orcad Layout 15.x i had done!!
Anyone can help me??
Thank's!!!
  • oldmouldy
    oldmouldy over 13 years ago
    Certainly the MIN file format was specific to OrCAD Layout and not provided by any other tools. You will need to find out what information is required and extract that in a format supported by PCB Editor.
  • RobZan
    Thank you for replay!!
    And the .asc file???Is supported by PCB Editor???
    Thank's a lot!!
  • oldmouldy
    If you mean a PADS format ACSII file, the answer will be no. You need to know the "why" and "what" is required, and then get the data in a supported format from PCB Editor.
