  3. Convert to pspice
  • Subscribers 163
  • Views 14968
Convert to pspice
Electronic1
Electronic1 over 13 years ago
Hi, I want to convert the text hspice to pspice voltage sources, and I have a problem
Hspice source:
 Gint 0 60 POLY(2) 31 0 53 0 0 0 0 0 ‘F0*Cin/(k*Cdif)’
pspice source: ???????
Gint 0 60 POLY(2) (31,0) (53,0) 0 0 0 0 {F0*Cin/(k*Cdif)}
Hspice source:
Gmlrr1 0 53 POLY(2)  40 0 10 61 0 0 0 0 -1 Min=0
Gmlrr2 0 53 POLY(3) 53 0 40 0 10 61 0 0 0 0 0  0 0 0 0 0
+ 0 0 0 0 ‘alpha*MS/k’ Min=0
Pspice: ????????????????
Gmlrr1 0 53 POLY(2)  (40,0) (10,61) 0 0 0 0 -1 {Min=0}
Gmlrr2 0 53 POLY(3) (53,0) (40, 0) (10 ,61) 0 0 0 0 0  0 0 0 0 0
+ 0 0 0 0 {alpha*MS/k} {Min=0}
Help hspice:
web.engr.oregonstate.edu/.../chapter_5.pdf
  • Alok Tripathi
    Alok Tripathi over 13 years ago
    You can get the complete details about PSpice Polynomial sources under "Basic SPICE polynomial expressions ( POLY)"  topic from "PSpice Reference Guide" book.
    Here is an example:
    HSpice: Gint 0 60 POLY(2) 31 0 53 0 0 0 0 0 ‘F0*Cin/(k*Cdif)’
    PSpice: Gint 0 60 POLY(2) (31,0) (0,53) 0 0 0 0 {1*2/(3*4)}
    Where under expression {1*2/(3*4)} 1,2,3,4 are values of parameters F0, Cin, K, Cdif. Do use expression, instead replace these with values.
    PSpice does not support MIN, MAX while declaring the sources.
    Hope this helps.
