  3. ps to pdf converter path in tcl/tk
  • Views 4378
hithesh
hithesh over 12 years ago
I am trying to use the pdf export option under Accessories in orcad. I have a pdf converter installed.
When I try to print I get "Postscript to pdf converter not found in path"
How do I enter the path of ps to pdf converter in tcl/tk.
There are 3 options - Adobe distiller, gs to pdf and custom. I tried with distiller and gs to pdf. No luck.
I downloaded gs to pdf converter. But I don't know how to enter the path. It's a bit strange, its not the usual c:\....
  • oldmouldy
    oldmouldy over 12 years ago
    The Ghostscript command line in the TCL script is looking for gswin32c.exe, add the path to this to the PATH Environment Variable for the machine, Control Panel>System, Advanced tab, Environment Variables,add the directory for gswin32c.exe to the end of teh System PATH entry with a semi-colon - ; - in front of it. The script will then find teh converter, (You could set the entire path in the TCL script but this will not be very "update proof")
  • hithesh
    oldmouldy,
    I am using pdfcreator to print files to pdf format.
    I entered the path in "system variables" in Environmental variables.
     In tcl/tck pdfexport menu, for the postscript driver, I entred "pdfcreator" and for ps to pdf converter, I entered "custom"
    What should I enter in the path window? I just entered the path for pdfcreator.
    I tried leaving it blank and also tried entering "pdfcreator"
    I Still get the same message - ps to pdf converter tool not found in path....
  • steve
    steve over 12 years ago
    Cadence provide full installation instructions to get the pdf to work. You need to follow the instructions found in <your_install_dir>\tools\capture\tclscripts\OrCAD_Capture_TclTk_Extensions.pdf. Page 85 onwards goes through the printer setup and installing either Ghostscript (free) or Adobe Distiller (licensed) which is the postscript to PDF converter.
