  3. Hilight/Dehilight through Constraints manager
  • Subscribers 163
  • Views 1587
Mstrghettorigg
Mstrghettorigg over 13 years ago
Hi all,
I'm on 16.3 and I was able to hilight/dehilight through the constraints manager with no problem for a while.
All of a sudden I am unable to dehilight the nets from the constraints manager.  Has anyone had this problem before?
I am also not able to dehilight the nets in Allegro.
I am able to do assign colors and once I try to dehilight from allegro it goes back to the color it was hilighted to on constraints manager.
Thank you in advance.
  • Ejlersen
    Ejlersen over 13 years ago
    Hi
    Could it be that it is defined as custom colors in the color/visibility dialog?
    Go into that dialog and try "disable custom colors" to check if this is the case
    Best regards
    Ole
  • Mstrghettorigg
    Thank you for the feedback.
    I didn't even know that color dialog had nets options this whole time.
    Worked like a charm.
    Thanks!
