  3. problem with IGBT model from advanls Lib
  • Views 14698
Hussein82
Hussein82 over 13 years ago
I am tying to use the AA pspice to tune the IGBT parameters.I am using orcad 16.3.
When adding the IGBT component from the "advanls" library, a simulation error occurd! Although the IGBT is connected and there is no floating pin, I have a floating pin error message:
"ERROR:  [NET0085]
Part Q1 has no 'RCA' property"
Can you please help.
Hussein
  • oldmouldy
    oldmouldy over 13 years ago
    There is nothing wrong with the connections, the part is missing a property value. Right-click the part in the schematic, Edit PSpice Model, in the Model Editor specify a value for RCA, thermal resistance case to ambient, in degrees C per watt to represent an attached heatsink. or not, as the case may be. The RCA won't be specified in the library because the part may be available in different packages with different Case / Ambient thermal resistance, or the part may be used with a heatsink with asignificantly lower thermal resistance, so there is no way to have a meaningful "default" in the library.
  • Mohammad Taha
    Mohammad Taha over 12 years ago
     Hello!
     I want to use the AD539 component from the advanls library in pspice but I can't find the library itself. Also, I've been told that I have to have a license for the Advanced Analysis Library in order to be able to use this model so how can I know whether I have this license or not.
    Please help as I really want the model for this component.
    Thank you in advance
