  3. Expanding status bar in Allegro 16.3/16.5
  • Subscribers 163
  • Views 902
phandinh1508
phandinh1508 over 13 years ago
Hi everyone,
 I have a question need your helps, much appriciated with your suggestions.
The net naming in my design is too long so that does't fit in Status Bar (please refer attached picture). So, is there any way to expand the Status Bar (particually in Net name) inorder to fit in long net name ?.
(I probably know other ways to see the net name by showing Element or Property Tab)
Thank you,
Have a good day all.
  • oldmouldy
    oldmouldy over 13 years ago
    If this is of concern, you should raise an enhancement request to get this section of the Status Bar enlarged. If you hover over the Net, you get the datatip with the name. 16.6 embeds the net name in the etch, so it might be argued that the Status Bar is not really required for the Net Name to be seen when selected.
