  3. database has errors (artwork generation)
  • Views 20001
FrancisFogarty
FrancisFogarty over 12 years ago
Hi guys,
When im generating athe artwork/gerber files with the check database before artwork option checked. i get six similar errors. the error as shown in the log file is
ERROR IN BRANCH name = SA
  ERROR(SPMHUT-17): Schedule contains an illegal disconnected branch.
NET may have lost connections. Check for missing connections.
i dont know how to deal with this really. i looked at the etch connection on the board and it seems to be fine.
i updated DRC and no errors found. all 6 errors are the same just different brance name.  Any ideas?
also if i run the artwork without "check database before artwork checked" will this be ok?
Regards
Fran
  • oldmouldy
    oldmouldy over 12 years ago
    Try a Tools>Database Check, set all the available options and Check, this should correct the connection issues. Probably best not to generate the artwork with database errors.
  • FrancisFogarty
    Thanks once again oldmouldy. that did the job.cheers
  • TH Designs
    TH Designs over 12 years ago
    I have had gotten errors/warnings when generating artwork and no hint as to what the problem is. Just a comment that the artwork was generated with warnings. I have found, as OM has suggested, that if I run the dbdoctor it clears up these warnings. I have now made it part of the process, before generating any artwork, I run dbdoctor. Since I started doing this I no longer get any warnings.
    Tom
  • FrancisFogarty
    Thanks Tom, ill add this to my checklist.
