  3. Cross Section Chart
  • Subscribers 163
  • Views 14462
Cross Section Chart
vin5488
vin5488 over 13 years ago
Can we customize the cross section chart.
  • oldmouldy
    oldmouldy over 13 years ago
    Not beyond the options in the dialog. If you look in some older posts in the PCB SKILL forum, there were some user contributions to this before the Cross Section was added to PCB Editor, you might be able to take one of those as a starting point and "roll your own", you will probably need the ability to use SKILL debugging which requires at least an Allegro PCB Designer licensed product.
  • oldmouldy
