Home
  • Products
  • Solutions
  • Support
  • Company
This search text may be transcribed, used, stored, or accessed by our third-party service providers per our Cookie Policy and Privacy Policy.
  • Products
  • Solutions
  • Support
  • Company
Community PCB Design & IC Packaging (Allegro X) PCB Design Generating gerbers
  • Replies 10
  • Subscribers 169
  • Views 19485
Generating gerbers
FrancisFogarty
FrancisFogarty over 12 years ago
Hi Guys
im getting a few warnings in the log file when generating gerbers.
WARNING: more than one via class in film record
    WARNING: Null REGULAR-PAD specified for padstack VIA188 at (-576.17 -530.00)
is it ok to leave these warnings alone?
Regards
Fran
  • jemarods
    jemarods over 12 years ago
    In addition, i would like to ask if there are other ways of generating artwork aside from Manufacture-Artwork. Maybe an export command for this.
     Thanks in advance.
  • steve
    steve over 12 years ago
    There are skill programs avaliable that will automate the output (gerber, ipc356, nc etc). Take a look on the PCB Skill forum or write your own. There is also an OrCAD App called Release Manager that will do this for you.
    http://www.orcadmarketplace.com/undefined/ProductDetails/tabid/93/ProductID/37/Default.aspx
  • sunilachar
    sunilachar over 10 years ago
    Hi guys, I have generated gerber from board file. The fab drawing.art file has dimensions of the PCB. But while viewing in GC preview i am not able to see the PCB thickness(text). What could be the error?
  • SevenFortyOneB
    SevenFortyOneB over 10 years ago
    Try setting the undefined line width parameter in the Artwork Control Form to something other than 0 and see if that helps.
  • lex13
    lex13 over 3 years ago in reply to SevenFortyOneB
    Hello. I have the same issue but for other 30 pads and hadn t resolved it. Can you help me?
