  3. DFA spreadsheet value ?
  • Subscribers 163
  • Views 14967
kabalee
kabalee over 13 years ago
Hi everyone,
in my design has BGA,VME connector,ADC and DAC and passive components like cap,res,diode are available.for DFA spreadsheet i need to set value between BGA to BGA ,BGA to CAP,VME connector To cap in spreadsheet.my customer could not give any value
how to set the value between components,
is there any doucement regarding DFA and guideline DFA is there
if there reply for this post >>
  • oldmouldy
    oldmouldy over 13 years ago
    You are only going to be able to find this out from the Assembly machine / method. If you are going to hand assemble you are likley going to need to allow more space than for machine assembly. Equally for machine assembly, you are going to need to find out how much space the component handling mechanism is going to need, this might be minimal if the handling uses some suction method but will be larger if the handling uses some form of "claw". If you speak to your assembly house, or assembly machine provider, they will be able to supply you with the parameters for their component handling requirements for different components.
  • oldmouldy
