  3. Manual entry of components
  • Views 18286
tmd63
tmd63 over 13 years ago
Is there any way of manually adding a component to an Allegro PCB design using PCB Design XL in the same way that you could in OrCad Layout.
I have been able to copy a footprint but the component is unassigned  (R*) and I cannot find how to assign it a new part number and to connect nets to it. In Layout, there was a feature that allowed you to add components and manually stitch nets to them.
  • tmd63
     Thank you Steve,
    That has fixed my issue. Althought there were still errors on the devices about pin names and un-named pins. But at least I got my new part in without removing all the other components.
  • tmd63
     Thank you Steve,
