  3. footprint script fail
  • Subscribers 163
  • Views 14811
frank2215
frank2215 over 13 years ago
I have a problem when I want to import a footprint through Ultralibrarian software. Ultralibrarian exports a library including a script file to run at Allegro PCB software. The problem is that I run the script an error is produced. "Can't find window; Form.padedit"
Someone was happen some like that?
 regards
  • eDave
    eDave over 13 years ago
    You have a mismatch between your version of Allegro and the version that Ultralibrarian expects. I don't think that Cadence guarantees that scripts won't change between releases so the Ultralibrarian developer should have avoided using this method if possible.
  • frank2215
    Ok, thanks for your reply. Texas Instruments for example uses bxl files for provides the footprint for your products. If I can't use Ultralibrarian to export a Allegro format, how I can proceed for get the footprints models? It is a shame if we can't use bxl files, because exists a lot of models in bxl format.
  • eDave
    UltraLibrarian appears to use 14.x. Try using the earliest version of Allegro you can get your hands on for the import..
