  3. SCHOTTKY DIODE
  • Views 15881
SCHOTTKY DIODE
abhierao
abhierao over 12 years ago
I am using a circuit which runs at 105khz - 250khz in sweep analysis, i want my ac voltage to be converted to dc via a bridge rectifier. as normal diodes don't work well at these frequencies i opted for schottky diodes, can anybody please suggest me which diode to use. my requirement is 40v, 1a. I don't find schottky in the basic pspice library.
  • oldmouldy
    oldmouldy over 12 years ago
    There are a bunch of SPICE diode models listed at this location http:__www.diodes.com_products_spicemodels (fill in the slashes) one of these might fit your needs.
  • abhierao
    thank you for the website i did find my required components. i am new to orcad capture & i am learning on my own so i didn't understand this part when i clicked on "download spice model" in that is a notepad file which gave me this info " *SRC=1N6263W;DI_1N6263W;Diodes;Si; 60.0V 15.0mA 1.00ns Diodes Inc. Schottky .MODEL DI_1N6263W D ( IS=1.82u RS=2.80 BV=60.0 IBV=200n + CJO=2.65p M=0.333 N=1.70 TT=1.44n ) " i don't know what i should do with this please help..
  • oldmouldy
    Start the Model Editor, Start>Programs>Cadence>Release "version">PSpice Accessories>Model Editor. File>New, Model>New, "any" model name and From Model, get the curves, View>Edit Model, replace the default model text with the Notepad text for the model, then File>Save As and save the LIB file. File>Export to Capture Part Library, to create the graphical OLB file. In Capture, Place>Part, Add Library to add the OLB file. In the PSpice Simulation Profile, Configfuration Files, Library, browse for the LIB file and Add to Design.
    See the pspug.pdf, in the doc\pspug directory of the installation, Appendix C "Importing Spice Models".
  • abhierao
    Thanks a lot. Things are working out very well now & i am clear of what i should do.
