  3. Reg: Flash Symbol & Gerber output
  • Views 2004
girish
girish over 13 years ago
Hi
I need your help to solve below issue
Current I am doing very old board revision activity , which used negative artwork for the plane & flash symbols for PTH.
1) I have not worked with negative plane artwork before , connection shown in is a very thin “+” sign on plane as shown in image , I really doubt
    how exactly its connected to [ plane fully or only + connection ] . This pin carries 15A current !, I suggested to change the plane to positive artwork , due some standards
    they didn't allowed me to change . Please let me how can I increase the connection width ? I exported libraries  & checked but some issue with flash symbol .
2) While generating Gerber files its throwing below error & unable to process
Your suggestions are highly appreciated
Best Regards,
Girish Kumar
  • BillZ
    BillZ over 13 years ago
    You need to recreate the original flash symbol. The .ssm that is referenced in the padstack is missing. I would consider switching the new design to positive.
    BillZ
    EMA Design Automation
  • TAyres
    TAyres over 13 years ago
    Why do you recommend that? How does one go about it?
