  3. Pls give me a suggestion to solve the "error(spmhod-29)...
  • Views 5896
Pls give me a suggestion to solve the "error(spmhod-29)"
ping2murali
ping2murali over 12 years ago
Hi, i'm new to pcb design tool , i received some .brd and .dra and .psm file from my friend for my practice, he did this on Allegro sp 16.6 but i'm using Allegro sp 16.5 lite. when i open those file i receive the following error.
ERROR(SPMHOD-29): Unable to open design because database was saved under a newer release and contains features not compatible with this version of software. See the newer release's documentation for any conversion capability.
Pls help me to solve this error.
  • oldmouldy
    oldmouldy over 12 years ago
    You need to download and install version 16.6 Lite version, or get your friend to export the files as an earlier version File>Export>Downrev Design. If you get the design downrev'd you can export the libraries with using File>Export>Libraries. Version 16.5 tools won't open files created with later versions.
  • ping2murali
    Thanks brother, it works.
