  3. Sliding vias across dynamic fill copper shape boundaries...
  • Views 1534
Sliding vias across dynamic fill copper shape boundaries - PCBDesigner 16.6
AnthonyK
AnthonyK over 13 years ago
 Hi
I'm using PCB Editor 16.6 and routing a 6 layer board with several inner power and ground planes defined as dynamic fill copper shapes with the relevant nets attached.
I'm trying to slide clines which have top-to-bottom (not blind or buried) vias.
I find that the vias won't cross the inner layer shape boundaries smoothly and I certainly can't get a via to sit on top of the edge of the shape.
I can place a new via on a shape boundary but when I slide it later it just jumps to one side of the boundary or the other.
I've tried all sorts of settings of "slide" options and "shape" options like deferring dynamic fill, disabling DRC and so on without success.
So: any ideas on how I can get vias to slide smoothly across dynamic fill copper shape boundaries?
Thanks in anticipation...
  • AnthonyK
    It works!  Many thanks, Craig,  for the information and for reducing my blood pressure.
    I use the slide function all the time for manual routing and find it really usefull. I'm surprised that this problem has to be resolved by an undocumented function.  As I missing something here I wonder, like a better way to shift clines and vias than using "Slide"?
    Anthony
  • AnthonyK
    Anthony
