  3. Dimension at point is not associated with an object
  • Views 12837
TAyres
TAyres over 12 years ago
Hi all,
I'm trying to measure from aribtrary points in PCB Editor, however I select the first point and I get "Dimension point at ... is not being associated with an object."
 How do I measure between two arbitrary points? I checked the algroman and algrostart and couldn't find it.
 Thanks!
  • TAyres
    I had a large component grid that was apparently one 'object'; I hid the layers containing it, then was able to select dimensions that would otherwise intersect with that object. This allowed me to measure the object. TL;DR version: I had the object, then once the space was blank, I could click there to dimension from it.
