  3. Resize Reference Designators in PCB Design L?
  • Views 16436
Canyonbreeze
Canyonbreeze over 13 years ago
 Is there a way to resize the reference designators in PCB Design L?  Text is easily resized in the schematic using F8 and F9 but I'm unable to find a corresponding function in the PCB editor.
  • redwire
    redwire over 13 years ago
     Text sizes can be changed in the Setup->Design Parameters menu, then under the "Text" tab.  Click on the "..."  (Setup Text Sizes) button.  Change the appropriate text type to the size you want.
  • joma
    joma over 13 years ago
    Edit > Change. Select Text block and choose your size. Make sure find is set to text.
  • Canyonbreeze
     Thank you for the suggestions.  Changing the design parameters didn't affect the existing text.  Edit > Change worked after clicking Text Block in the option panel.
  • EvanShultz
    EvanShultz over 13 years ago
    You may have already thought to try this, but you can turn on only the subclass containing the ref des, enter Edit > Change and adjust the parameters, then draw a box around all ref des elements. That way, you can change all existing ref des items at once.
  • redwire
    Of course it does, that is how Allegro is designed.  You did something wrong.
