  3. PSpice A/D accuracy in V16.3?
  • Views 1195
makeit
makeit over 12 years ago
 Did some simulation with high dynamic range (using a SUM ABM Model : adding a constant value of 1 with a sinus-wave having 120nV as amplitude) . I was supprized getting quantized data with a LSB of 60nV which corresponds to single precision (mantissa hase 23 + 1Bits). Is there any chance to get double precision?
Here my sim settings:
****     OPTION SUMMARY
  OPTS
DC ANALYSIS -
    ITL1 =  150
    ITL2 =   20
  RELTOL =    1.0000E-03
  ABSTOL =    1.0000E-12
   VNTOL =    1.0000E-09
    GMIN =    1.0000E-12
VLTEXPLIMIT =     .5
TRANSIENT ANALYSIS -
    ITL4 =   10
TSTEPDIVFACTOR =    8
  CHGTOL =   10.0000E-15
DMFACTOR =    1
FSTDELFACTOR =    1
MISCELLANEOUS -
  NUMDGT =   10
   WIDTH =   80
    DEFL =  100.0000E-06
    DEFW =  100.0000E-06
   DEFAD =    0
   DEFAS =    0
    TNOM =   27
 Thanks!
  • oldmouldy
    oldmouldy over 12 years ago
    16.6 has 64-bit Probe data format, pretty certain that would be the issue. Not possible before 16.6
  • makeit
    I did the same simulations with LTspice (V4.11) setting the option NUMDGT = 6 and 7.
    In the first case I get the same result as with PSpice --> single precision.
    With NUMDGT = 7, LTSpice switches his output to double precision.
    Thanks for your answer!
