  3. PCB Editor (Allegro) Get Distance (Dimension) Between Two...
  • Replies 7
  • Views 34980
PCB Editor (Allegro) Get Distance (Dimension) Between Two Points
TAyres
TAyres over 13 years ago
I want the edge-to-edge distance between these two pads, however whenever I select Dimension->Dimension Environment, then right click and select Linear Dimension, and select each of the pads, I keep getting the pin-to-pin dimension. What should I select in order to get a 'dumb' dimension?
I realize that I could take the pin-to-pin dimension, subtract half of the width of the rectangles on either side, and obtain my measurement, but I'm sure there's a way to do this automatically and I just don't know it (yet!)
Thanks!
  • oldmouldy
    oldmouldy over 13 years ago
    Do you want to know what the distance between the pads is, or do you want a dimension to show the distance between them?
    Distance between them, use Display>Measure, click on the pads in turn, the "Air Gap" will be the Pad Metal to Pad Metal distance.
    For the dimension, which version are you using? (The "Snap pick to" differs between versions)
  • TAyres
    I'm using 16.6 Display->Measure, clicking on the pads, then "Air Gap" distance was the one I was looking for. If I DID want a dimension there, how would I go about it in 16.6? Thanks for the help!
  • Pawandeep
    Pawandeep over 13 years ago
    In Menu of 16.6 go to Manufacture>Dimension Environment
    RMB choose Linear Dimension. Use Find Filter View to select the items eg Pins/Symbols etc
    RMB choose Parameter option to change default settings including the unit of distance
    -Pawan
  • Pawandeep
    Here is the link to the App note from Cadence regarding Dimensions.
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:doc;src=wp;q=ApplicationNotes/Silicon-Package-Board_Co-Design/Dimensioning.pdf
  • mcatramb91
    mcatramb91 over 13 years ago
    I don't believe the current dimensioning functionality has the ability to dimension the Air-Gap between elements (ie. Pins) to provide the same results as the Display > Measure Air Gap calculation.
