  3. How can I import Autocad dwg file to orcad capture/layout...
  • Subscribers 166
  • Views 5760
How can I import Autocad dwg file to orcad capture/layout. ? n also how can I design a round shape pcb board for led light using or cad.?
Indorg
Indorg over 12 years ago
  • steve
    steve over 12 years ago
    You can't import a autocad dwg file but you can import and autocad dxf file. Simplify what you need to import in Autocad and then save a DXF file. Then go to PCB Editor and use File - Import  - DXF. Take a look at http://www.youtube.com/watch?v=wTegtW9bPCs
     To create a round PCB draw a Circle (Add - Circle).....
  • tmd63
    tmd63 over 12 years ago
     There are a few things to remember with the dxf import. OrCad has a problem with some types of lines and files.
    I normally use polylines in AutoCad and it is a closed polyline for the board outline. Then save the file as a version 12 dxf.
