  3. ERROR [NET0011] Netlist failed or may be unusable.
  • Views 16123
jimmymaci
jimmymaci over 12 years ago
Trying to make a PCB from a layout file.
I create a netlist and get the following error
I attached a screen shot of the connector but im not sure it will do any good.
what does the error mean
ive gone througha and redrawn the circuit about 5 times, tehre are no extra nodes or anything present that shouldnt be there
Design Name: H:\ELECTRICAL\SONOTHERM PROBE CABLE LAYOUT\INTERCONNECT\FORIGATE\JIM.DSN
WARNING: Name contains illegal characters 'HEADER 13X2', changed to HEADER_13X2
WARNING: Name contains illegal characters 'Sonotherm PCA', changed to Sonotherm_PCA
  • oldmouldy
    oldmouldy over 12 years ago
    Every Pin on the right hand connector has a DRC marker, could that be something to do with not generating a netlist? Which netlist format are you trying to generate? Zip the DSN file and attach it to the Post.
  • jimmymaci
    ok, the file should be attached here
    JIM.zip
  • oldmouldy
    From the data format, you are using version 16.2, or earlier, and trying to generate an EDIF netlist from the "Other" tab. The EDIF netlist has some formatting requirements, hence the "Illegal names" messages - but the netlister will handle that by removing the issues in the output data. The primary problem is that you have an invalid Reference for the Header part, valid references start with a letter, conventionally to indicate the part type, end with a sequence number and do not contain spaces. You have J2 for the second connector, J1 might well be an appropriate reference for the other.
  • jimmymaci
    ok, i got it work, thanks.
    Its funny as it said it was just a warning about the name of that so i figured i could ignore it
    was looking for errors
