  3. Forcing via connections
  • Subscribers 163
  • Views 16048
tmd63
tmd63 over 13 years ago
 I have a multi-layer design with multiple ground plane layers. But these have issues with ground loops. How can I set something in PCB Editor 16.5 that will only connect vias to one ground plane layer and leave all other layers unconnected, so that I can use a single ground connection point.
  • tmd63
     That almost worked. I set the thermal relief for global dynamic shapes to none. Selected the shape where I wanted the connections and RMB the selected parameters and changed the thermal relief for that layer without problems.
    But the single pin to connect the other planes did not work. I have added 4 traces from that pin to the copper pour for each layer instead. This has worked this way.
    Thanks.
  • tmd63
    Thanks.
