  3. Schematic file not paste in OrCAD 9.2 ???
  • Subscribers 162
  • Views 14681
Dhamodharann
Dhamodharann over 13 years ago
Hi..
                    I had drawn schematic in OrCAD 16.0, in that i had copied the content of that schematic and try to paste it in OrCAD 9.2.But when i tried to paste it the capture 9.2 was closed automatically. So there is any possible solution.
Thanks & regards,
S.Dhamodharan
  • kabalee
    kabalee over 13 years ago
     Hi dhamu,
    you cannot paste the schematic diagram from Higher version to lower version if you want to change the schematic (orcad 16.X to orcad 9.0) better follow this method.
    open orcad 16.X version.
    file---export--> EDIF(no error message will come while completed process)
    open fresh schematic file -->import-->EDIF file.(library with design file is generate)
