  3. PCB EDITOR 16.6 and 16.3 on the same computer?
  • Subscribers 162
  • Views 14290
CCR77
CCR77 over 13 years ago
        I just installed 16.6 on my computer under the assumption I could still launch 16.3.  16.6 is up and running as anticipated, however if I try to launch 16.3 I get the following error.
"The program can't start because cdn_xerces-c_2_7.dll is missing from your computer.  Try reinstalling to fix this problem."
 Did the install of 16.6 delete or move this .dll?  Should I reinstall 16.3?  Any guidance would be greatly appreciated.
Clint
  • TH Designs
    TH Designs over 13 years ago
    You need to use the switch release feature to switch the licensing between 16.6 and 16.3.
  • CCR77
     Thanks for the pointer Tom! The Switch Release Tool is working as intended.
    Thanks again,
    Clint
