  3. Preferred method of editing Orcad CIS parts database
  • Subscribers 163
  • Views 15383
PaulFrechette
PaulFrechette over 13 years ago
I am looking for suggestions on what software I can use to modify part attributes that are in my Orcad CIS database.  For example, a resistor manufacturer has changed there numbering scheme.  So, I would like to open the database in a spreadsheet format and do a global replace of text for these parts.  I am using Microsoft SQL Server 2008 and I am not a database expert.  Just looking for an easy way to edit.
  • oldmouldy
    oldmouldy over 13 years ago
    The database is the "other side" of the ODBC interface so Capture CIS has no means to modify it. If you can't use the SQL tools to modify the database through the SQL Server "management console", you could link Microsoft Access to the SQL Server database through ODBC and then use the Microsoft Access interface and commands to modify the data.
