  3. Generating footprint, want to import pin location list
  • Replies 8
  • Subscribers 166
  • Views 18101
TH Designs
TH Designs over 12 years ago
I'm generating a footprint for a cylindrical connector that has 61 pins where each pin has a specific x/y location that is not on a grid. I see that there is a command under File>Import called "CSV Pin File". I am making the assumption that by using this command I can point to a CSV file that contains the pin number and coordinate for each pin.
I'm looking for a clue as to how to set up the CSV file. When I search the "help" files I don't seem to find any info on using this command. I have searched through the help files for mayn things related to importing CSV files such as CSV Pin import, File Import CSV, Green Cows, etc....... all returned nothing useful. I have even clicked on the "help" button in the CSV Pin file input dialog box, but that just takes me to a general page of commands by letter.
I'm sure this is probably a very simple process, I just need to know the required format of data in the CSV file.
Tom
  • steve
    steve over 12 years ago
    Hi Tom
    The csv format needs to be:-
    <pin number, padstack name, x position, y position, rotation, text offset x, text offset y, text rotate, mirror>
  • TH Designs
    Thanks Steve.
    Now the $2 question, where did you find this info?
    Tom
  • TH Designs
    What is the syntax for "mirror"? Y/N or True/False, or.....?
    Tom
  • steve
    From File - Export - CSV Pin File from an existing dra....
    The mirror is for text mirror m for mirrored and blank for not mirrored.
  • TH Designs
    Good idea, thanks
