  3. Allegro does not show the measurement dialog box
  • Views 22649
shatwood
shatwood over 12 years ago
Hi there!
I am usign OrCAD PCB Allegro, in former times it allways showed the "show measurement(alt+F4)" dialog box.
Since this morning it does not appear, has anyone har a problem like this?
I've used windows+tab to scroll to all open windows, but it does not show up.
regards
  • BillZ
    BillZ over 12 years ago
     Hi.
    If you used Allegro previously with dual monitors and now your using a single monitor the GUI might still be opening on the second screen.
    Locate your PCBENV folder and delete the allegro.geo file. reopen Allegro and see if the GUI comes back.
    BillZ
    EMA Design Automation
  • oldmouldy
    oldmouldy over 12 years ago
    You might have more luck with Display>Measure, or shift+F4, the Alt+F4 shortcut is reserved by Windows.
  • shatwood
     Thanks for your help, i used two monitors prviously, as i used "windows+p" and changed to one monitor thewindows appeared!
     After that i changed back to two monitors, now it's working great!
     regards
