  3. Output impedance of a buffer
  • Views 13547
tltoth
tltoth over 12 years ago
Could anyone suggest a method to determine the output impedance of an iocell from ibis curves. The values from V/I curves are far from exact and the Trial and Error method is rather time consuming.
  • Ejlersen
    Ejlersen over 12 years ago
    Hi
    Using SigXplorer I would create a small circuit consisting of 2 iocells connected with a series resistor and a tline
    Setup a sweep of the series resistor value and then take the tline impedance - resistor value for the best simulation results will give you a very good indication of the the output impedance of the iocell. You'll probably have to select something that suits you for both Falling and rising edge.
    Best regards
    Ole
  • tltoth
    Thank you Ole!
    This is what I meant about Trial and Error because my license does not support sweep in Signal Explorer. But the method does really work.
