  3. Where are all the classes/sub classes gone for "Dimension...
  • Subscribers 167
  • Views 1382
Where are all the classes/sub classes gone for "Dimension in 16.5, 16.6" ?
ScottCad
ScottCad over 12 years ago
Hi guys, for some reason I am unable to add dimensions to the package sub class and a whole buch of others too. Seems like the dimension classes/sub classes have been reduced to only a few classes in the current release. Was wondering is there a way to make the classes that can hold a dimension the same as existed in 16.2
Main ones I need are
Package Geometry > Assy top, Assy Bottom
Board Geometry > Assy_Detail, Assy_notes
Drawing Format > Title Block
I tried a bunch of things but cant seem to make them show up.
Thanks Scott
  • PRASH36
    PRASH36 over 12 years ago
     Hi
    You can add new subclass by Setup--->Subcalss , add the new subclass under respective Class ,Now open  Colour Dialog box (ctrl+F5)  and at the top click  Global vissibility --->ON
  • steve
    steve over 12 years ago
    Dimensions can be on any of the following:-
    Board Geometry - Dimension, Assembly_Notes, any user defined subclass.
    Drawing Format - Any user defined subclass
    Manufacturing - Any user defined subclass.
  • ScottCad
    Hi Guys thanks for the help on this. I figured out what was going on. I was using parameter files from a prior ver of Orcad/Allegro and these files had the subclasses I typically use. When I imported the parameter file my layers or sub-classes show up.
    By default when you start 16.5 you will have a highly limited selection of classes and subclasses if you are just using a blank board "System default" but if you load up a symbol  for example that had a user defined subclass on the Package Geometry class you will still be able to use that class/subclass going forward in the new editor.
    Works good :)
    Thanks Again Scott
