  3. Merging of PADs with Ground plane
  • Views 14298
raul5565
raul5565 over 12 years ago
I have a board with the GND copper filled. I am using Allegro PCB design L (Legacy)
There are the PADs of the componets which has to be grounded, are right now gets connected to the GND plane with the 2 single tracks one vertical and one horizontal, instead of completly merging with the GND plane.
Is it possible to merge the PADs completly with the GND plane????
  • oldmouldy
    oldmouldy over 12 years ago
    Set the Find Filter for Pads only, hover over the pad, right-click>Property Edit, add the Dyn_Thermal_Conn_Type of Full Contact, this will remove the Thermal Reliefs from the Pad(s).
  • raul5565
    thank you very much, it helped a lot, i am doing it only on few components, having SMT PADs which has no thermal relief. i need one more information if you can tell me, do we have the Thermal relief on the SMT PADs??
