  3. Orcad 16.5 : Problem with moving objects
  • Views 14072
Swilam
Swilam over 13 years ago
Hi all,
I am using Orcad PCB Design and I can't see the component while moving them, when I try to move any component it disappear then when i click on the new place it appears again. Any recommendations about how to make it visible.
thanks,
Swilam
  • Ejlersen
    Ejlersen over 13 years ago
    Hi
    Try going into the properties of your Graphics adapter and change the settings for acceleration. Normally there's a slider for that, try and see if that helps. If not, try disabling opengl and see if that helps, its done inside setup->user preferences in PCB Editor.
     You could also try updating to the latest release 16.6
    Best regards
    Ole
