  3. Round hole, square peg......
  • Replies 8
  • Subscribers 163
  • Views 18037
TH Designs
TH Designs over 12 years ago
 New one to me...........
I have a board where we have decided to put a few non-plated holes around the board to be used for debug purposes incase we need to run some wires from the bottom layer to the top layer for modifications and such. I have a mechanical hole that when I place it anywhere on the board, the solid copper layers produce a void of a square instead of a circle. I have other holes of similar nature used for the mounting holes that were placed the same way but give me a nice circular void.
So, why the square void vs the circular void? Both pad stacks have the same structure except the drill diameter is smaller fo one vs the other. Both holes are non-plated and have pad sizes smaller then the drill size so the pads get drilled away.
  • mcatramb91
    mcatramb91 over 12 years ago
    The reason I asked you to check if you had a circular Anti-Pad was if you enabled the Padstack option "Mech pins use antipads as Route Keepout", it would use the Anti-Pad feature defined in the padstack as a Route Keepout to void the plane.
    If you don't have Route Keepout defined and have not enabled the Anti-Pad as a Route Keepout in the padstack then the shape void will be based on the drill size using the Hole to Shape spacing check which I believe defaults to 8mils.
    PS. As I am typing this, I just saw your response that you found the Sq Route Keepout in the symbol, great! - still thought it would be good to close the loop with this follow-up post anyway.
    Hope this helps,
    Mike Catrambone
  • TH Designs
     Mike,
    Sooooo many options, so little knowledge.............
    Thanks for the tip.
    Tom
  • redwire
    redwire over 12 years ago
    So true...and an attitude to go with it!!
