  3. Round hole, square peg......
  • Replies 8
  • Subscribers 163
  • Views 18035
TH Designs
TH Designs over 12 years ago
 New one to me...........
I have a board where we have decided to put a few non-plated holes around the board to be used for debug purposes incase we need to run some wires from the bottom layer to the top layer for modifications and such. I have a mechanical hole that when I place it anywhere on the board, the solid copper layers produce a void of a square instead of a circle. I have other holes of similar nature used for the mounting holes that were placed the same way but give me a nice circular void.
So, why the square void vs the circular void? Both pad stacks have the same structure except the drill diameter is smaller fo one vs the other. Both holes are non-plated and have pad sizes smaller then the drill size so the pads get drilled away.
  • TH Designs
    Example:
  • mcatramb91
    mcatramb91 over 12 years ago
    If the padstack has a circular Anti-Pad than the only other thing that I could think of is a Sq Route Keepout/All shape is defined in the symbol which is causing the dynamic shape Sq void.
    Hope this helps,
    Mike Catrambone
  • TH Designs
     Hmmmmm...........
     Pad stack has no antipad defined on any layer. Maybe?
  • TH Designs
     No antipad was defined, BUT no antipad is defined on the other hole that has the circular void.
  • TH Designs
    Hope this helps,
    Mike Catrambone
    Mike,
    Yup, square route keepout defined. Deleted it, now all is well with the world.............. until the next snag.
    Tom
