  3. No Pspice library for line driver and receiver
  • Views 13396
mfoggia
mfoggia over 12 years ago
Hello everyone.
I have the lite version of orcad and I have the following problem. I'm trying to develop a time simulation of a circuit with a line driver and a line receiver RS 422 but every time I launch the simulation shows a green dot on the drivers that report: "WARNING: [NET0093]
No PSpiceTemplate for U1, ignoring "
the components I want (drivers and receivers) are all in the capture library LineDriverReceiver but no PSpice library.
someone can help me solve the problem?
thanks to all
max
  • oldmouldy
    oldmouldy over 12 years ago
    The Capture libraries are for PCB design and don't have any PSpice related properties attached, you need to use the parts from the PSpice libraries to get the required properties attached. The list of provided PSpice parts is in the lib_list.pdf, in the doc\lib_list directory of the installation. If you cannot find the required part within the provided libraries, you will need to see if you can find a PSpice (SPICE) model for the part on the vendor's web site and make a Capture / PSpice part to use it in your simulations.
