  3. SMA/SMB footprint in Orcad 16.5
  • Views 3639
sns22
sns22 over 12 years ago
Hi all,
I going to use a SOCKET, SMA, RIGHT ANGLE, 50OHM in my PCB link here uk.farnell.com/.../1248989
I was able to find the smb_90.dra and smb_90.psm files in the Allegro Starter / Evaluation Library Cadence_Starter_Library Downloaded from the Cadence web page www.cadence.com/.../allegrodownloadsv2.aspx
However there is no padstack available for same.
Can anyone tell where to get the footprint for the connector?I put these files in the C:\Cadence\SPB_16.5\share\pcb\pcb_lib\symbols. When I add the pcb footprint in my design The design check rules works good. But when I try to create a netlist in the design I get a
WARNING:(ORNET 1119)NO spice template ignoring. And it ignores the connectors in Orcad Capture.
Can someone help me with the footprint for the same.
Sneha
  • kabalee
    kabalee over 12 years ago
     Hi sneha,
    please check the footprint here i attached
    LIB_TE.zip
