  3. Lock (lck.)files
  • Views 17650
Lock (lck.)files
RonScott TI
RonScott TI over 12 years ago
All,
I need some general information on what induces a .lck file? I've run across this many times inthe past and I just delete the pesky file and move on. I've bee doing work for remote sites and a particular user (using my template) is managing to create .lck file. I having been advising the user delete the .lck or close /reload file. The .lck file doesn't seem to intefere with activity of Concept but the user thinks we can get rid of the .lck forever. Any ideas?
Ron Scott
  • Jerry GenPart
    Jerry GenPart over 12 years ago
    Hi Ron,
    The Design Entry HDL (DEHDL or ConceptHDL) .lck files are generated whenever a designer opens a page of a schematic. If another designer attempts to open the same page of the schematic, they will receive a warning that the page is in read-only mode and they will not be able to write to that page. At times, these .lck files become "orphans" and remain after the original designer is not longer running DEHDL. The main cause is if DEHDL crashes.
    So, if you determine that nobody is actively editing the page, you may remove the .lck file(s) with no negative consequences.
    Jerry G.
