  3. Creating Guard Rings
  • Views 17170
Beques
Beques over 13 years ago
I am working an example learning how to do PCB design using Allegro PCB editor from the OrCAD 16.6 suite, and I'm having a problem where, when I try to put a guard ring around a through-hole pin, it erases the trace when I place the last point of the arc.  It won't let me place a complete circle.  Is there something I'm doing wrong?
I've placed a via from ground to the top routing layer, a straight trace that goes above my pin, then as I place the arcs around the pin, it will not let me complete the circle.  If I click to place the last point of the arc, it erases the whole thing and has me start over again.
  • redwire
    redwire over 13 years ago
     Make sure "Replace Etch" is unselected.  This can be found in the "Options" tab when routing.  This is typically a fly-out window on the right side of the screen.  Allegro is attempting to minimize the route length.  There are other methods too with shapes/voids that can be used as well if interested.
  • Beques
    I tried again with "replace etch" unchecked, and it did the same.  It lets me get 3/4 of the way through routing the trace, then when I go to place the last point to complete the ring, it erases the whole circle and I have to start over.
  • Nayyierwajih
    Nayyierwajih over 13 years ago
     if you have to make circle then use ADD-->CIRCLE
    if you will use ADD-->ARC W/RADIUS then you will be able to make only arc not complete circle.
    Nayyier
  • redwire
    Agreed that Add->Circle is more appropriate.   I think you are wanting to add vias at specified increments?  You can do this with Edit->Copy, then adjust to "Polar" coordinates and adjust the angle, etc...
    Otherwise you can do the add-Arc method but you need to set up your grids correctly.  Add a via at each segment which is what I think may have been missing?
